Author Topic: Enable Security  (Read 3800 times)
Zidane
Enable Security
« on: September 05, 2006, 04:40:18 am »
In version 6.5.796 the "Enable Security" option can be found under Project/Security menu.
In the version 6.1.791 this option is not available, although it is described in help to be found under Project/Security.
Using a common DBMS repository, will the two versions work together correctly?!
Best regards,
Dietmar
Jan ´Bary´ Glas
  • Bary
Re: Enable Security
« Reply #1 on: September 05, 2006, 04:55:49 am »
If your 791 is Corporate it should work, I have 791 installed, and security in that place is visible and we are using it.
So first check if you have Corporate edition, second reinstall, third report to Sparxians.
Jan 'Bary' Glas
Zidane
Re: Enable Security
« Reply #2 on: September 05, 2006, 05:56:02 am »
1) Yes it is the Corporate edition
2) 3) Is not necessary. I work with a common repository and can enable security mode and manage users with v6.5.796. This is not possible with (my) v6.1.791 (corporate) but sec mode is recognized and login, locking of objects, etc. works. Will upgrade to 6.5 anyway.
Thanks you very much for the fast reply.
Best regards,
DD
