Author Topic: Baseline management GUID based?  (Read 2662 times)
« on: September 05, 2006, 12:44:42 am »
I just wanted to get confirmation that Baseline Management is GUID based.  That is, if you attempt to import a file as a baseline for the current model the root package's GUID must match that of the model you are importing into.
As a consequence, it is NOT possible to compare one model branch against another (conceptually identical) model branch.
Can anyone confirm this?
TIA,
Re: Baseline management GUID based?
« Reply #1 on: September 05, 2006, 03:09:50 pm »
Yes, it is guid based.
This means that the comparison will work no matter what changes are made to any element, at the expense as you say that it can't be used to compare 'similar' packages that were created independently.
sargasso
« Reply #2 on: September 06, 2006, 12:25:34 am »
How about this?
Create a new model.
Export/import package A without Guids
Create a baseline
Export/Import package B over the top of A
Baseline & compare
Havent tried it - but it doesn sound promising eoither
bruce
p.s. if mt typing sounds shakey its because two pepole just tried to do u-turns into me on main roads within ten minutes of each other.  Both in toorak tractors.
« Reply #3 on: September 06, 2006, 06:55:16 am »
You're obviously hard to kill ;D
