Author Topic: Use Case Scenario, Textual Description  (Read 4236 times)
SinoKaya
« on: September 08, 2006, 02:57:10 pm »
Say I created a use case modeling element.  In its element properties, I went to Scenario tab and entered textual descriptions for the Basic and Alternate paths.
Is there a way to show this text on a diagram, say on a note or any other modeling element, without doing a cut-and-paste.  That is, the text and the "note" on the diagram are at synch?
I'm using EA v6.1
« Last Edit: September 08, 2006, 02:57:38 pm by SinoKaya »
Re: Use Case Scenario, Textual Description
« Reply #1 on: September 08, 2006, 03:15:11 pm »
Yes you can.
Although I am using 6.5, the procedure should be the same. Look up "Linking Notes to Internal Documentation" in the EA HTML help. The idea is explained there, but the next page - titled "Link a Note to an Element" - actually tells you how.
When you follow the directions there are two things to keep in mind:
  • You can usually save a bit of time by right-clicking the use case and selecting Add / Note from the context menu.
  • Remember that to link to the element (step 4 on the help page) you need to right-click the note link. [I seem to be completely incapable of remembering this myself, so always have to fumble around wondering why it failed.]
Once you fill out the resulting dialog you'll get the results you described.
HTH, David
Jan ´Bary´ Glas
  • Bary
« Reply #2 on: September 11, 2006, 01:43:23 am »
Haven't tested in 6.5.797 yet, so I cannot tell if it is working for constraints as well, I didn't, but it should.
Jan 'Bary' Glas
« Reply #3 on: September 11, 2006, 03:44:51 am »
Yes, it works fine for constraints in 797. In particular, on the same element you can attach a note to a constraint, as well as another note to, say, a scenario.
SinoKaya
« Reply #4 on: September 11, 2006, 01:05:34 pm »
Thanks! The tips worked for me.
