Author Topic: Build scripts and debugging  (Read 3447 times)
Sandman27
« on: September 11, 2006, 03:16:48 am »
I am using EA for reverse engineering some older projects in order to create proper documentations of the sources. For that reason, I created a build script which basically tells EA how to compile the project.
Now, when I try to debug the project in EA, it gives me an error "Failed to load common language runtime". What does it mean? Did I configure something wrong? There is on limited information available about how to write build scripts for different environments.
BTW, I am using Borland Delphi 7.
Re: Build scripts and debugging
« Reply #1 on: September 11, 2006, 02:54:49 pm »
Common Language Runtime = .Net
Although you can create any build script for EA,  it only supports debugging .Net and Java applications at the moment.
Sandman27
« Reply #2 on: September 11, 2006, 10:38:57 pm »
Thanks a lot!
