Author Topic: Importing a WSDL  (Read 3723 times)
visean
Importing a WSDL
« on: September 11, 2006, 09:13:11 pm »
Hi Folks,
I am getting the following error importing a WSDL file into Enterprise Archnitect.
Loading WSDL File....OK
Reading Header Information....OK
Creating WSDL Package : WMLS....OK
[StoreSoapBinding] Binding operations donot match [StoreSoapPort] PortType
Error in Operation : WMLS_AddToStore
Deleting Created Package....OK
The WSDL File can be found here http://staging.visean.com/unsecure/witsml_wmls.wsdl
If anyone has any Ideas, it would be greatly appreciated !
Regards
Mark
« Last Edit: September 11, 2006, 09:17:33 pm by visean »
VK
Re: Importing a WSDL
« Reply #1 on: September 11, 2006, 11:58:46 pm »
The culprit seems to be the comments under the WSDL PortType - these comments are causing the WSDL Importer to fail.
In the file you had specified, under the portType "StoreSoapPort", you will find the following 2 comments :
<!-- <operation> elements define the function signatures (operation name and parameters) and associate the input and output messages  -->
<!-- parameterOrder attribute values must be separated by a single space  -->
Delete these two comments and EA will import the WSDL successfully.
We will have this bug fixed for Build 798.
