Author Topic: association classes  (Read 2389 times)
rabra
association classes
« on: September 13, 2006, 06:46:12 am »
Hallo,
In class diagrams there is the possibility of creating association classes by using the connector 'association class'. A new class is generated which now can be used like a 'normal' class.
But in the development process it may happen that I create a class, use it etc. Later I see that this class must be an association class for 2 other classes, but I do not see a possibility to change it in this way. I only see the possibility to use an 'association' (n-ary association). But when using the association I do not see a possibility to make visible that one of the associated classes is 'the association class' (except for giving another colour to the connector).
Re: association classes
« Reply #1 on: September 13, 2006, 03:17:12 pm »
In the context menu of a class (on a diagram) there is an option "Make Association Class", that allows you to connect it to any association on the diagram.
