Author Topic: Code format?  (Read 3553 times)
ukmtk
Code format?
« on: September 20, 2006, 03:42:54 am »
If one uses the inbuilt editor or even the code generation facility is it possible to alter the format of edited/generated code?
Or is it up to the user to do this in an external editor/environment?
Re: Code format?
« Reply #1 on: September 20, 2006, 04:32:42 am »
Both Mike,
There's a lot you can do by customizing the generation scripts. As a starting point - at least for formatting the output - take a look at the PO macro and other literal text handling. [In build 797 you will have to search on PI in the HTML help to find these two entries.] Follow through the documentation for more ideas.
EA's capabilities go a bit beyond what you'll find there, but are certainly not extensive. You can extend things by editing on the 'outside' with any good code editor. If you are experienced with a top-end editing environment you may find it useful to create some custom macros there, which look for EA-generated constructs and tweak them to your specifications.
HTH, David
