Author Topic: Using SourceGear Vault  (Read 3907 times)
Ed
« on: September 19, 2006, 07:07:32 am »
I’m using SourceGear Vault for my source control provider but I’m having trouble getting EA to use anything other then the root $ folder for the SCC Project Folder.
I have read the Setting up Version Control document but still no luck.
I right-click on my root-node and select Package ControlVersion Control Options.
I select the SCC check-box, I enter a unique configuration ID, I set my local project path to a folder on my local machine and select Vault from the list of Source Code Control Providers.
When I click on Save I get prompted to connect to Vault and select an SCC Project/Vault folder.
I select an existing folder that is empty and press OK but then I receive several error messages.
Error: SC_E_UNKNOWNPROJECT
Followed by: “Error while initializing version control.  Failed to open SCC Project”
If I select the root/$ node everything works fine.  Except I really need to place the EA files under a different folder then root/$.
I’m using the latest Vault version 3.5.1 and EA 6.1.792
Any ideas?
Ed
jnapier
Re: Using SourceGear Vault
« Reply #1 on: September 22, 2006, 01:24:02 pm »
Try removing the text from any text that is in the Project To Add text box.
For some reason it tries to append that text to the actual folder already selected.
kt1
« Reply #2 on: September 25, 2006, 07:14:51 pm »
I have other question with SourceGear Vault. I configured my project successfully. However, how can I shared it with my team members? When they open project from their PC, there are error message about configuration. Can you tell me detail the way to do that?
Thanks :P
Ed
« Reply #3 on: September 26, 2006, 05:55:58 am »
Yes I tried this but still no luck.  It only works if I choose the root project folder .   ???
Ed
« Reply #4 on: September 26, 2006, 08:06:24 am »
I was able to connect to TFS source control and store the models under a different folder so I think i'll continue down that path instead of Vault.
Ed
