Author Topic: XML Comments  (Read 3199 times)
h2oskier
XML Comments
« on: September 26, 2006, 12:14:22 pm »
Is there a way to change the formatting of the XML comments generated by the xml_comment function in the code templates.
Re: XML Comments
« Reply #1 on: September 26, 2006, 02:57:04 pm »
No you can't change the results of that macro.  You have two choices if it's not what you want.  Either use it, assign it to a variable and post-process it, or create your own template that generates how you want.
