Author Topic: problems with package access after version control  (Read 3275 times)
iMikel
« on: January 23, 2008, 06:17:05 am »
i am using the java automation interface.
The method Repository.GetPackageByGuid(String)
does no longer work, after a package has been set under version control (IBM clear case in my case).
I retrieve the GUID of a tree selected Package by a special programm, what i call a Java-Wrapper, and access the package in turn by the above method; this does work perfectly, as long as the package is not version controlled.
Does anyone know a solution or maybe i should work with the ID instead of the GUID?
Greetings from Germany
Re: problems with package access after version con
« Reply #1 on: January 23, 2008, 07:20:28 am »
You should send in a registered users bug report if you can reproduce that.
