Author Topic: Problem reverse engineering C++ code  (Read 3379 times)
roberthauck
« on: September 27, 2006, 03:05:49 am »
Hello
I have a c++ header file like that:
#ifndef XMLPARSER_H
#define XMLPARSER_H
struct SceneObject
   std::string objectname;
   SceneObject(std::string oname){objectname = oname;}
class XMLParser
public:
   XMLParser();
   ~XMLParser();
//General XML loading and writing
   bool WriteXMLFile(std::string filename);
#endif
If I import it into EA 6.5.797 I get the following error:
There was an error parsing XMLParser.h on line 41.  Unexpected symbol: SceneObject
You may need to define a language macro.
Line 41 is "struct SceneObject"
If I define a Preprocessor Macro, it gives me an error on the next line with the {.
Am I doing something wrong?
Thank you
Robert
Bokkie
  • Lima Bravo!
Re: Problem reverse engineering C++ code
« Reply #1 on: September 27, 2006, 05:24:37 am »
Hi Robert,
I've copied your code into a .h file, reversed engineered it to C++ and no errors where reported. Perhaps you should check your settings once more...
Regards, M.
Lima Bravo!
roberthauck
« Reply #2 on: September 27, 2006, 05:36:49 am »
Hi
I found the error, I deleted code, just to show you the struct, but the error is actually at the line when I define the namespace for Xercec:
XERCES_CPP_NAMESPACE_USE
If I delete that line, it works without errors. I now made a Preprocessor Macro for that, and it imports the header file without errors. Is that the correct way of doing it? ???
Thank you for your help
Robert
Bokkie
  • Lima Bravo!
« Reply #3 on: September 27, 2006, 05:40:54 am »
using namespace xercesc_2_7;
Lima Bravo!
