Author Topic: Poss. Bug (797): HTML Documentation  (Read 3384 times)
barry_abs
« on: October 03, 2006, 03:40:28 am »
Hello all,
Could anybody help me understand the following problem regarding the HTML Documentation generator?
In the documentation output folder, opening "index.htm" from my file explorer ("file://" scheme) works.
Opening "index.htm" via my webserver ("http://" scheme) returns this error message: "An error occured while loading data files, please confirm that all files have been generated and are intact."
Any ideas?
Many thanks,
Lloyd
« Last Edit: October 03, 2006, 03:43:13 am by barry_abs »
mikewhit
  • Accessing ....
Re: Poss. Bug (797): HTML Documentation
« Reply #1 on: October 03, 2006, 03:57:15 am »
Sounds more like a webserver config problem than an EA one.
Which app is reporting the message you quote ?
Does your webserver have permission to access the HTML files ?
Do the files have absolute path links in them ("C:\....." which the webserver does not translate correctly ?
Jeff Odell
« Reply #2 on: October 03, 2006, 04:00:52 am »
I reported a bug and received a solution from Sparx on this one.  Their workaround fixed this for me, at least in my case.
The error is thrown in a JavaScript routine that calls back to the server to get data that represents the tree structure on the left side.  This causes a problem on IIS - at least in my Windows 2003 environment.
Here was the fix provided:
The issue with Windows 2003 is currently a known issue that will be fixed in a future release, however there is a workaround to make it work now:
- Open the IIS Manager
- Select the specific Web Site
- Bring up the Web Site Properties
- Open the "HTTP Headers" tab
- Click the "MIME Types..." button
- Click the "New..." button
- Enter ".dat" in the "Extension:" field
- Enter "text/html" in the "MIME type:" field
- Hit "OK" 3 times
HTH - jlo
barry_abs
« Reply #3 on: October 03, 2006, 04:29:23 am »
Thanks Jeff - i will try that solution, albeit the webserver here runs IIS4 on NT4 Server.
1. The error message is reported by the index.htm page
2. Yes.
3. No. The URL which works is "file://///itgweb/datalogging$/Model/index.htm". It fails with "http://<SNIP>/datalogging/model/index.htm".
barry_abs
« Reply #4 on: October 11, 2006, 02:28:51 am »
Morning..
We have fixed this issue now.. The solution was a combination of two things:
* Make the IIS MIME type changes, as above
* Configure ".dat" as safe in microsoft's crappy URLscan tool.
Cheers,
Lloyd.
« Last Edit: October 11, 2006, 02:29:26 am by barry_abs »
