Author Topic: Reverting to earlier baseline  (Read 3215 times)
morsor
  • insert text here
« on: October 16, 2006, 03:44:52 am »
Will one only be able to revert to an earlier baseline if it was explicitly exported to XMI at the time - or does EA internally store the XMI of all baselines?
Re: Reverting to earlier baseline
« Reply #1 on: October 16, 2006, 03:27:25 pm »
All Baselines are stored as XMI.
morsor
  • insert text here
« Reply #2 on: October 16, 2006, 11:00:50 pm »
I know baselines are stored in XMI - but how do I revert to an older baseline?
There is no 'Revert to baseline' or 'Import baseline' option.
The only option I can find is 'Import File' and 'Export File'.
If I knew where the baseline XMI was stored, I could import that. Where is the XMI stored?
If the baselines are in fact only stored in the EAP-file, it seems necesary to explicitly export baselines to be able to re-import them.
So my question is: Where (file location) are the baselines stored?
« Reply #3 on: October 16, 2006, 11:07:14 pm »
There is no file location, they are stored within your repository.
The baselines dialog gives you the possibility to export them to a file.  You can then import that as you would a normal XMI file.
morsor
  • insert text here
« Reply #4 on: October 16, 2006, 11:28:33 pm »
OK - just to check:
To be able to revert to an earlier baseline, I will have to export that baseline.
« Reply #5 on: October 17, 2006, 03:12:46 pm »
Yes.
