Author Topic: EA 6.5 performance under Win98SE  (Read 6397 times)
SF_lt
  • The Truth Is Out There
« on: October 11, 2006, 08:23:14 am »
Recently I have noticed, that EA 6.5 (797 & 798 builds) performance under Win98SE OS degradated. I mean, that visual EA response is noticable - that wasn't in effect untill 6.5 version. Another observation is, that part of EA startups are invisible - EA is running, process list shows it, however there is no window, so I can't use it. Only solution is to kill process and start EA again.
I'm not sure, do I have to report this behaviour as a bug.Also, I would like to get other users responces, who use EA 6.5 under Win98SE OS - did they encounter similar behaviour.
EA 6.1 worked like a charm - there wasn't such problems as with the 6.5 version
registertm everything to SparX
SF_lt
Re: EA 6.5 performance under Win98SE
« Reply #1 on: October 12, 2006, 11:40:16 am »
these issues were reported as a bug/request
SF_lt
« Reply #2 on: October 25, 2006, 06:06:46 am »
One of the effect on Win98SE; also, sometimes there are crashes with the BSOD message for user.exe file
if you can advise any debugger or logger for Win98SE, which could log odd things (even during crashes) - advice
« Reply #3 on: October 25, 2006, 03:22:57 pm »
I can't see your image, it's showing as a broken link.  (Although I'm sure I saw it flash briefly when I first loaded the page)
SF_lt
« Reply #4 on: October 26, 2006, 12:56:32 am »
strange, because I'm seeing it  ;D
maybe it's because I'm using Firefox and it understands PNG format...
« Last Edit: October 26, 2006, 01:08:16 am by SF_lt »
Jan ´Bary´ Glas
  • Bary
« Reply #5 on: October 26, 2006, 01:24:26 am »
There were some problems with pictures recently. The solution was to empty Cache a twice refresh. I don't know why, but it usually works.
/I can see the image in FF./
Jan 'Bary' Glas
« Reply #6 on: October 26, 2006, 03:26:27 pm »
IE (here) manages to half load the image then clears it and show the broken link.  Clearing the cache means that it tries to load it again and the same thing happens.  IE handles PNG images normally without a problem.
