Author Topic: BUG: Search BRAIN DEAD  (Read 3037 times)
« on: October 30, 2006, 09:18:55 pm »
I have two classes in the model with the same name.  One has a stereotype, the other hasn't
If I use the Find in Project Browser tool [Ctrl+Shift+F]  and say I want an exact match on the name of the class, it will only find one...  The one without the stereotype.
If, on the other hand, I use the Search Project [Ctrl+F] I cannot find only them using ANY of the existing predefined search strategies.
[BTW: If you want to find only those classes in the project with a given name, use simple search, edit the search so that only the name is the available filter, change the "contains" to "equal to" <search term> AND MOST IMPORTANTLY (redundantly) check the Required check box!]
Do I have the right to be exteremely frustrated (insert your expletive here) by a product whose search strategies are so BRAIN DEAD?
Grrrr...
« Last Edit: October 31, 2006, 12:56:50 am by PaoloFCantoni »
SF_lt
  • The Truth Is Out There
Re: BUG: Search BRAIN DEAD
« Reply #1 on: October 31, 2006, 12:48:41 am »
Paolo, use registertm strategy  ;D
registertm everything to SparX
« Reply #2 on: October 31, 2006, 12:57:19 am »
Don't worry, I have...
