Author Topic: Import/export of UML profiles, howto  (Read 2394 times)
Jan van Mastbergen
« on: November 10, 2006, 08:27:32 am »
 ??? Hi,
(Using build 799) In the release notes for build 796 (?) I read that it is now possible to export UML profiles to UML2.1/XMI2.1 format but I do not seem to be able to invoke that for a single profile selected in the resource pane. Is there a way to do just this?
When I import a profile file there, will it accept only the Sparx .xml format for the profile or also the UML2.1/XMI2.1 variant?
I am aware that you can edit a profile graphically in a EA database and then export it to the Sparx .xml format and import/use it elsewhere. Is there a way in to edit and use it within one and the same database?
TIA, Jan
Jan ´Bary´ Glas
  • Bary
Re: Import/export of UML profiles, howto
« Reply #1 on: November 12, 2006, 10:55:29 pm »
In build 800 you may import .emx as well.
Jan 'Bary' Glas
