Author Topic: Generate Communication Diagram  (Read 2347 times)
danilo_04
« on: November 14, 2006, 07:39:23 pm »
Hi, i want to generate a communication diagrama from the Sequence Diagram. How do it.!!
Re: Generate Communication Diagram
« Reply #1 on: November 14, 2006, 08:29:14 pm »
There is an (unsupported) add-in at http://sparxsystems.com.au/downloads/mdg_technology/C2SEQ.exe which performs the conversion in either direction. A couple of hints:
1. If, after installing, you don't see the "Add-Ins" menu on the main menu bar, try "View | Visual Layouts | Default Layout" to reset the menus.
2. The Sequence-to-Communication conversion works best if you use Objects rather than Lifelines on your sequence diagrams (i.e. don't use the Lifeline element from the toolbox but Ctrl+Drag a class element and choose "Instance" when prompted).
3. The conversion won't create associations between objects if they don't already exist, so the created communication diagram may look odd.
danilo_04
« Reply #2 on: November 15, 2006, 07:56:26 pm »
I already used it and it served to me. Thank you very much
