Author Topic: Importing Glossary Terms  (Read 4262 times)
mlac
« on: November 19, 2006, 06:38:54 pm »
I am a new EA user and am have been trying to  import CSV files to populate the EA Project Glossary and Project Issues.
Is this possible?  Do I have to use the automation interface? Or develop a custom SQLServer script?
The thought on manually entering hundreds of items is a bit daunting.....so any help is appreciated!
Cheers,
Martin
« Last Edit: November 19, 2006, 06:40:35 pm by mlac »
Re: Importing Glossary Terms
« Reply #1 on: November 20, 2006, 12:18:58 am »
Martin,
import/export of the Glossary is possible via XML (see Tools/Im-/Export refrence data).
Also you can import the glossary directly in EA's database. EAP files are MS Access databases. You will find the table names rather self-explanatory (you even can reverse engineer a database and analyse it with EA itself). From memory the glossary's table is named t_glossary.
Similar goes for Issues.
« Reply #2 on: November 20, 2006, 11:38:03 am »
Since I keep tripping over this myself, I'll add that the items in question are listed as "Project Glossary" and "Project Issues." You'll find these in the list offered by the Tools | Export Reference Data dialog.
mlac
« Reply #3 on: November 20, 2006, 01:11:07 pm »
Thanks for your suggestions.....but I need a bit more advice on each:
1. How do you convert a table of glossary items (residing in a CSV file) into an XML file ready for importing?
2. How do you view/access EAP tables via MS Access?
Cheers,
Martin
« Reply #4 on: November 20, 2006, 01:54:43 pm »
1. If you export the glossary using the command "Tools | Export Reference Data" then open the output in a text editor you will be able to see the XML format expected for the import. The same applies for exporting the issues.
2. An .eap file is a renamed .mdb file. Just open it!
« Reply #5 on: November 20, 2006, 02:28:49 pm »
Alternatively define an MS Access ODBC source pointing to any .EAP file.
