Author Topic: Version 5.0 - Build 767 Released  (Read 19474 times)
sparks
« on: June 15, 2005, 10:09:37 pm »
Fixed generation of methods from multiple realised interfaces.
Fixed VB.Net parser to allow Shadows keyword on inner classes.
Made the source editor save using the "Output files use both CR & LF" option.
Corrected issue where the RTF Generator would incorrectly generate noteless elements when the "Hide Noteless Elements" option was turned on.
Added External Requirements as a document section in the new RTF generator
Updated RTF (basic template) to include external requirements
Corrected issue where the "Exclude image from RTF document" option was ignored in the new RTF Document generator.
Fixed issue where images of GIF/PNG/WMF file types were unable to be imported or viewed in the RTF Template editor and Internal Viewer.
Fix issue generating Implementation Report on MySQL repositories.
Fixed issue where documents generated with the new RTF generator would incorrectly generate root packages when the Skip Root Package option was enabled.
Fixed issue where Paste Appearance wasn't marking diagram dirty.
In HTML documentation, made hyperlinks clickable even when not "selectable" in original diagram.
