Author Topic: RTE VBA  (Read 3891 times)
RTE VBA
« on: November 21, 2006, 02:46:38 pm »
I'm trying to round-trip-engineer some MS Word 2000 VBA code.
I've set the language to VB6
However, the following VB Attributes:
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = True
Attribute VB_PredeclaredId = False
Attribute VB_Exposed = False
do not round-trip in Word.
That is, they are set by EA on Forward Engineer (Generate) but if I import the module into Word and then export it again, they are not preserved.
This means it is not possible to use file comparators (such as Beyond Compare) to track changes as there are ALWAYS meaningful changes...
Is there any way to suppress their Generation?  (Even if registry settings)
TIA,
Re: RTE VBA
« Reply #1 on: November 21, 2006, 03:19:11 pm »
Well, for starters you can remove those lines from the Class Declaration template.
It may also be worth checking what version of VBA is being used by word.
Re: RTE VBA
« Reply #2 on: November 21, 2006, 05:25:50 pm »
That will do thanks, Simon.   :D
I suspect Word VBA is more like VB4.  Does anybody know?
Re: RTE VBA
« Reply #3 on: November 21, 2006, 07:10:49 pm »
I reached a similar conclusion myself at one point.  But I don't know it for certain.
Re: RTE VBA
« Reply #4 on: November 21, 2006, 07:13:42 pm »
Having had a look at the code templates, I can see a number are customised for VB5 vs VB6
Would it be possible to get VB4 added and then we can customise the templates more "Correctly"?
Support for VB4 (MS Office 200 VBA)
« Reply #5 on: November 22, 2006, 06:52:49 pm »
Further to this suggestion:
You can jury-rig a solution with the following changes:
In the t_genopt table, change the value in the Option column for the class row form:
sVVersion=5.0 or sVVersion=6.0 (depending on your current setting) to sVVersion=4.0 - this is NOT currently allowed by the GUI but hopefully it will...
In the Visual Basic Class Declaration template add the conditional:
Attribute VB_Name = "%className%"
%if genOptVBVersion != "4.0"%
Attribute VB_GlobalNameSpace = %genOptVBGlobal == "T" ? "True" : "False"%
Attribute VB_Creatable = %genOptVBCreatable == "T" ? "True" : "False"%
Attribute VB_Exposed = %genOptVBExposed == "T" ? "True" : "False"%
Attribute VB_Ext_KEY = "SavedWithClassBuilder" , "Yes"
Attribute VB_Ext_KEY = "Top_Level" , "Yes"
%endIf%
Option Explicit\n
and in the Class template change the conditional from:
%if genOptVBVersion != "5.0"%
to
%if genOptVBVersion == "6.0"%
Then, as my son says...  "It's all good!"
Re: RTE VBA
« Reply #6 on: November 23, 2006, 04:24:51 am »
The problem is that VBA has its own version and specific syntax idiosyncrasies.
For some time now VBA has been at the 5.3 version level. This does not have any parallel with VB versions, and actually postdates VB 6.0.
There was an earlier version of VBA, and it was very much like VB 4. However, a lot of products have included the more recent VBA engine over the past (almost) 10 years so its unlikely you have this version.
Take a look in the registry or something - I simply don't know where to look, and my copy of the documentation is in the (hard to get to) archives - and perhaps you can find the VBA version.
Since VBA is so incredibly common, and since there are some (fairly limited) version differences from VB 6, it might be worth adopting VBA as yet another dialect for EA. As far as VB 4 goes, the macro tweak is perhaps the best bang for the buck. Even VB 6 is now a decade old, and VB 4 has essentially disappeared. [Yes, I know we dinosaurs see it occasionally, but some of us even feel the 60's really happened. Who you going to believe?]
HTH, David
