Author Topic: Stateflow labels keep realigning when moved  (Read 2694 times)
kfank
  • Yabba dabba do!  It's quittin' time!
« on: November 29, 2006, 10:59:25 am »
For example, I have a state transition with trigger "Sleep Timer Expired" and guard "Sleep Timer Enabled".  I resize the label text box so it displays as desired:
Sleep Timer Expired
[Sleep Timer Enabled]
But when I then click and drag to reposition it, it realigns to:
Sleep Timer
Expired
[Sleep TimerEnabled]
and again:
Sleep
Timer
Expired
[Sleep
TimerEnabled]
Is there a way to prevent this auto-resize behavior?
kfank
Re: Stateflow labels keep realigning when moved
« Reply #1 on: November 30, 2006, 02:25:59 pm »
In fact, when the state diagram is saved, closed, and reopened, the transistion labels may realign.  Very annoying when you spend the time to make the drawing readable then later the labels are on top each other or poorly formatted.
Control Freque
« Reply #2 on: December 01, 2006, 10:04:28 am »
Same problem with connector lables...seems to be generic problem with moving of labels.
