Author Topic: Element hyperlinks between separate EA projects  (Read 2455 times)
sheikspa
« on: December 01, 2006, 01:03:01 pm »
I'd like to know if there's a way in version 6.5 to have in a project linked elements from a separate project.
For example, I'd like to have a separate EA project for each application that I develope, and yet another project for the common components (use cases, clases, components, etc) shared by all of the apps, so when I need to add a common element in any of the app EA projects, I don't wanna have to copy-paste the common element, but simply copy it as a hyperlink to the common EA project, just like when you copy and paste elements as hiperlinks within the same project.
Thanks in advance!!!
     Adrián
Re: Element hyperlinks between separate EA project
« Reply #1 on: December 03, 2006, 01:21:33 pm »
I'd recommend using controlled packages as this does allow sharing of packages across multiple models.  See http://www.sparxsystems.com/EAUserGuide/index.html?controlledpackages2.htm
