Author Topic: Primary keys  (Read 6228 times)
Nonchalant
Primary keys
« on: December 13, 2006, 08:46:41 am »
Why do classes have the primary keys defined at the bottom.
Also what does embargo time mean?
Re: Primary keys
« Reply #1 on: December 13, 2006, 09:18:07 am »
OK, I bite.
What's the context here? The word "embargo" does not appear in the current (build 800) documentation at all. Perhaps this is from version control or a floating license; do you use either?
Re: Primary keys
« Reply #2 on: December 13, 2006, 01:53:05 pm »
The UML Data Modeling Profile, on which EA's data modelling is based, defines primary keys as operations.
In media terms, an embargo time is the time before which news agencies are not allowed to go public with a story. In EA terms, I have no idea...
Nonchalant
Re: Primary keys
« Reply #3 on: December 14, 2006, 01:26:12 am »
Thankyou that gives me my answer. so what about the primary keys in the classes (class diagram)?
Re: Primary keys
« Reply #4 on: December 14, 2006, 02:14:49 am »
I guess because they are grouped according to stereotypes.
Re: Primary keys
« Reply #5 on: December 14, 2006, 05:32:01 am »
If you are speaking about primary keys in Table elements taken from the Class toolbar, then that's what KP was referring to.
Sparx has used the Data Modeling Profile for UML (capitals intended, since this is an published work from an external source) as the paradigm for their data models. Since this profile is based on stereotyped class models, Sparx added the necessary components to their class modeling tool set.
Basically, KP was referring to how EA treats classes stereotyped as «table» elements. EA gives attributes of these elements a default stereotype of «column» and also stereotypes operations to indicate various keys and relationships. The default EA display settings group attributes and operations by stereotype and sort the groups alphabetically, although you can change these from the appropriate Tools | Options pages.
Nonchalant
Re: Primary keys
« Reply #6 on: December 15, 2006, 02:15:09 am »
thats great guys. all i wanted to know was could I lay out the classes so the primary keys are at the top rather than at the bottom of the class??? ::)
Re: Primary keys
« Reply #7 on: December 15, 2006, 05:24:50 am »
As I said: they are grouped according to stereotypes and you can't change the sort order (AFAIK).
Edit:Why not ask this before complaining?
« Last Edit: December 15, 2006, 05:26:04 am by thomaskilian »
Re: Primary keys
« Reply #8 on: December 15, 2006, 05:44:20 am »
And, since they are stereotyped operations they will appear in the operations partition, which is below the attributes partition (where the columns of the table are defined). Thus, you will have them at the bottom - or at least below the columns, in case you show additional partitions.
Nonchalant
Re: Primary keys
« Reply #9 on: December 18, 2006, 06:51:09 am »
thomaskilian.. what do u mean edit and what u mean AFAIK?
thanks guys again.
i wish EA was just straightforward.
mikewhit
  • Accessing ....
Re: Primary keys
« Reply #10 on: December 18, 2006, 08:03:24 am »
Edit - he made an edit
(As Far As He Knows)
Edit what do you mean "u"
« Last Edit: December 18, 2006, 08:04:20 am by mikewhit »
Re: Primary keys
« Reply #11 on: December 18, 2006, 09:36:48 am »
Or could that be "What do U mean by you?"  ;D
mikewhit
  • Accessing ....
Re: Primary keys
« Reply #12 on: December 18, 2006, 09:57:56 am »
Re: Primary keys
« Reply #13 on: December 18, 2006, 01:22:27 pm »
I feel like such a green; hopefully I've not made a complete glass of myself...
Full point awarded Mike!
Re: Primary keys
« Reply #14 on: December 18, 2006, 02:46:44 pm »
thanks guys again.
I mean by Edit: "I have written this very post but unfortunately made a mistake or forgot something so I'm forced to Edit the post and ammend the changes and in order you know what I did I put a meta-tag in italics here which might give you a clue." R U satisfied?
Edit:Typo, hopefully not confusing U.
« Last Edit: December 18, 2006, 02:48:27 pm by thomaskilian »
