Author Topic: counters during code generation or transformation  (Read 3328 times)
GBeutler
« on: February 21, 2008, 05:42:56 am »
Hi everybody,
I am generating a apache ojb mapping. In simple words this is a xml file which describe the mapping from at class to a database table.
At the xml file I need a attribute number which is the number of the position of the attribute at the table the attribute belongs to. It is only a counter like 1, 2, 3 etc.
Is there a way to get the position of an attribute at its table during transformation?
Thanks in advance and best regards,
Guido
Re: counters during code generation or transformat
« Reply #1 on: February 21, 2008, 08:09:48 am »
The code templates don't have any counting capability.  The best suggestion I can make at the moment is to try using an addin call to get the attributes Pos value.
You can do this using EXEC_ADD_IN.  You can search for examples on this forum.  But I'll include another one here.
Example C#
public String AttPos(EA.Repository r, object args)
   Array p = (Array)args;
   String attGUID = (String)p.GetValue(0);
   EA.Attribute a = r.GetAttributeByGuid(attGUID);
   return a.Pos.ToString();
Example template
%EXEC_ADD_IN("MyAddinName", "AttPos", attGUID)%
Hope that helps.
