Author Topic: stereotypes.  (Read 10460 times)
chrisHauert
Re: stereotypes.
« Reply #15 on: January 02, 2007, 06:32:47 pm »
I really was nonchalant for having hijacked your topic, Nonchalant, please forgive me  :-[ (I go with you, mikewhit:
Looked like you were happy with simonm's 7th Dec answer to the original post. Hence (I presume) the hijacking !
Thank's David for your useful answers:
thanks again, sorry for taking so long to react
« Last Edit: January 03, 2007, 12:47:34 am by chrisHauert »
Cheers, Christoph
Nonchalant
Re: stereotypes.
« Reply #16 on: January 03, 2007, 01:18:54 am »
dont worry bout it chris.. as long as we all get answers.. 8)
mark.myers
Re: stereotypes.
« Reply #17 on: January 02, 2007, 06:19:31 pm »
I am trying this same approach with sourcetoplabel and targettoplabel but it doesn't work.  I can successfully hide the middletoplabel but not the source or target toplabel.  Is a different approach needed?  More documentation would be good!
It's okay, I figured it out.  It's "lefttoplabel" and "righttoplabel".  Bit inconsistent but what the hey, it works!
Cheers, Mark
chrisHauert
Re: stereotypes.
« Reply #18 on: January 03, 2007, 12:54:42 am »
You're right
I've got an answer from sparx support with regard to the command 'setlinestyle()':
"The reason why the "setlinestyle" command is not recognized by the editor is because it is not specified in the list of keywords in "shape_syntax.xml". To work around this issue please add the following line to the file (Default location: - "C:\Program Files\Sparx
Systems\EA"):
<Keyword>setlinestyle</Keyword>
I have logged this as an issue and it shall hopefully be fixed in a future release of EA:
Issue ID: 07010419
Description: "setlinestyle" is not in the list of keywords"
Cheers, Christoph
