Author Topic: Reverse engineering a sequence diagram from Java c  (Read 2131 times)
ddunwoody
« on: January 08, 2007, 08:42:18 am »
I'm a new user of Enterprise Architect, and I'm trying to reverse-engineer a sequence diagram for a particular operation.
I've configured by codebase such that I can call the method in which I'm interested from a JUnit test case, and I've added a main() method to the test to allow this.
I've imported the code from my project directories, and set up the "Package build scripts".
However, I cannot get either the "Run" or "Debug Run" options to do anything.
As an example, I've put the following into the Build and Run > Package Build Scripts > Debug dialog box:
Class name to debug: com.sportex.betex.accountweb.payment.actions.CardDepositActionTest
Run time variables:jre=C:\apps\jdk1.5.0_06,-Djava.class.path="extremely long path that includes spaces"
If I decrease the length of java.class.path, the debug run will start, but then I don't have a sufficient classpath...
Is there a maximum limit to the length of the classpath that EA will accept?  As an aside, exactly the same commandline for run (java -classpath "long classpath" f.q.ClassName) works fine from the command line, but not from EA.
Any help much appreciated - I'd really like to rev-eng these diagrams and therefore justify paying for EA!
Thanks in advance,
