Author Topic: Problem Transformation Package Language  (Read 3961 times)
Ma-Lik
« on: February 23, 2008, 12:22:21 am »
I get a fault message, when I try to set set the language of a package at the transformation. Why is it not possible to set the language of a package like this:
%if packageStereotype == "foo"%
Package
name="Foo_Module"
namespaceroot="false"
%TRANSFORM_REFERENCE("FooPackage", packageGUID)%
stereotype = "CORBAModule"
[highlight]language = "IDL"[/highlight]
Class{
      name="FooClass"
      %TRANSFORM_REFERENCE("Interface", packageGUID)%
      language ="IDL"
      stereotype = "CORBAInterface"
      import=""
Without the highlighted line everything is fine, but not the language of the package...
Re: Problem Transformation Package Language
« Reply #1 on: February 25, 2008, 09:03:44 am »
EA never uses the language of a package, but that doesn't mean that it shouldn't allow a transformation to set a language.  I'd recommend sending in a bug report to sparx systems.
« Last Edit: February 25, 2008, 11:18:30 am by simonm »
« Reply #2 on: February 25, 2008, 11:02:20 am »
EA never uses the language of a package, but that doesn't mean that it shouldn't allow a transformation to se a language...
Hi Simon,
A small but subtle question if I may: do you mean "set a language" or "see a language" (as in determine what the language setting is)?
« Reply #3 on: February 25, 2008, 11:19:51 am »
Thanks David.  I meant "set" as per the original question and have corrected my above post to reflect this.
Ma-Lik
« Reply #4 on: February 25, 2008, 07:57:33 pm »
OK I will do it.
