Author Topic: Showing selected fields from tables  (Read 3939 times)
Martin Terreni
  • Sorry, I can't write
« on: January 19, 2007, 03:10:55 am »
Is there a way to create a view/class object showing some selected columns?
I need this so I can descrive quiries graphicaly like this:
As you can see here, only part of the tables columns are shown,this way I can descrive/design quiery logics for the developers.
« Last Edit: January 19, 2007, 03:11:51 am by martint »
Recursion definition:
Re: Showing selected fields from tables
« Reply #1 on: January 19, 2007, 03:53:27 am »
The only way I know of is to hide by stereotype. You can right click any element and select "Set feature visibility".
Martin Terreni
« Reply #2 on: January 19, 2007, 05:03:11 am »
It is a hard derty workarround, but it works.
Thanks!
Still there is no way I see to do the same with views...
Martin Terreni
« Reply #3 on: January 19, 2007, 05:33:20 am »
Doesn't work for reversed engineered tables, they keep the "column" stereotype.
« Last Edit: January 19, 2007, 05:34:03 am by martint »
« Reply #4 on: January 19, 2007, 05:59:44 am »
Of course you could always hide the «column» stereotype.  :D
Martin Terreni
« Reply #5 on: January 19, 2007, 06:13:43 am »
« Reply #6 on: January 21, 2007, 01:03:04 pm »
Which is done by opening the options dialog to the Objects page and clearing the 'Show <<column>> stereotype' checkbox.
As for the original question, 'Set Feature Visibility' in the context menu of the table on the diagram allows you to hide specific columns.
« Last Edit: January 21, 2007, 01:04:45 pm by simonm »
