Author Topic: Stateflow properties bug  (Read 2552 times)
Bokkie
  • Lima Bravo!
« on: January 22, 2007, 06:24:20 am »
In version 801 when drawing a stateflow, somehow the link name gets automagically (under unknown circumstances) filled in by EA with undesired information. (I'm only using the properties Constraints tab). Removing the link name in a normal manner doesn't work. However, when I empty the link name, click cancel and then click Yes to save the changes the link name is finally gone...
Lima Bravo!
Re: Stateflow properties bug
« Reply #1 on: January 22, 2007, 06:49:54 am »
I think this - or something quite similar - was noted as a bug fairly recently. I cannot remember if Sparx commented on it here in the forum. Nor can I remember if this dated back to 801, or was since 802 came out.
« Reply #2 on: January 22, 2007, 01:21:41 pm »
Hi Bokkie,
you may be experiencing: [size=13]BUG: Weighted "flow" edges corrupt name[/size]
If your situation is NOT identical, report a bug, otherwise, add a comment on my original post as it should be being monitored by Sparx.
« Last Edit: January 22, 2007, 01:22:07 pm by PaoloFCantoni »
