Author Topic: How to generate the charset clause for an att?  (Read 3007 times)
ericv
« on: March 27, 2006, 10:06:06 am »
I need to generate the MySQL charset clause for an attribute of a table in a data model.
For example:
CREATE TABLE tabname
attname VARCHAR(255) CHARACTER SET utf8 NOT NULL DEFAULT ''
) DEFAULT CHARSET latin1;
I have added a Custom Tagged Value 'CHARSET' on the table and it has worked fine.
But when I tried to apply the same method on the attribute,  nothing has been produced by the DDL generation.
I use EA 6.1.788.
Thanks for your help.
Eric
hd
Re: How to generate the charset clause for an att?
« Reply #1 on: March 27, 2006, 02:26:30 pm »
This is not available yet for MySQL columns.
We will add this feature in a future release.
ericv
« Reply #2 on: January 23, 2007, 06:40:15 am »
What's new about this feature ?
Now I use the version 6.5 802, is it possible to add the character set clause for a column ?
Thanks.
Eric
« Reply #3 on: January 23, 2007, 10:02:42 am »
Don't know Eric.
If not, you might be able to work around this somehow. Perhaps add a tagged value to the column element. Then tweak the generation script to check for the tag, and if it is present insert the clause using the value.
[Of course this would require direct access to the SQL generation function in EA. I don't remember off hand, but this might not be scripted, and thus impossible for use poor end users. Perhaps someone can shed some light on this.]
