Author Topic: Can't see requirements link  (Read 2816 times)
Martin Terreni
  • Sorry, I can't write
« on: January 29, 2007, 01:26:28 pm »
I linked requirements imported from Doors to the elements implementing them, but there is not "lniks" tab in requirements, all other entity types have (as far as I checked) is there a reason for that?
Recursion definition:
bioform
  • Forty-Two?
Re: Can't see requirements link
« Reply #1 on: January 30, 2007, 08:34:58 am »
Note: Requirements & Features are NOT really implemented as UML constructs in EA, so they do NOT have all of the same items available on their UIs...
BUT there are a couple of ways to "See" the information you are interested in:
1. Click on the legacy requirement, and then view it's realtionships using the "Hierarchy" window (short-cut to open is Ctrl-Shift-4)
2. Using the RTM feature in EA (read help on it, or just leave a message here... I try to respond the same day)
3. Using EA's Project|Documentation|"Implementation Details" report
Hope that helps!
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
bioform
  • Forty-Two?
« Reply #2 on: January 30, 2007, 08:36:28 am »
Also forgot!!
Just click on the object that implements them, and on it's requirement tab, you should see the link to the requirements (backward trace)
Forward trace from the "Requirement" see my comments...
Martin Terreni
« Reply #3 on: January 30, 2007, 11:09:59 am »
thanks, grate help.
