Author Topic: Generating delegate classes with code, list macro  (Read 3815 times)
GBeutler
« on: February 29, 2008, 03:34:52 am »
Hi all,
I try to write a transformation for creating a delegate class from an interface. The default code should be generated too like:
int testMethod(int arg)
   return ref.testMethod(arg);
My problem is how to get the dynamic list of attributes? I tried:
Operation
  %TRANSFORM_CURRENT()%
  %list="Parameter" @separator="\n" @indent="  "%
$attr=%list="Parameter" @separator="\n" @indent="  "%
  code=%qt%return ref.%opName%($attr);%qt%
This is not working. How can I create a String which contains the name of all parameters of the operation? Thanks in advance and
best regards,
Guido
« Last Edit: February 29, 2008, 03:47:48 am by GBeutler »
Re: Generating delegate classes with code, list ma
« Reply #1 on: February 29, 2008, 08:28:56 am »
You need to create a custom template.  Select the type 'Parameter' and give a name such as 'Name'.
Edit that template to just give the parameter name.
Parameter__Name
%opName%The list in the calling template would then use the custom template you chose.  (Note. Two underscores)
$attr=%list="Parameter__Name" @separator=", " @indent="  "%
GBeutler
« Reply #2 on: February 29, 2008, 08:29:12 pm »
ok, working now. To be complete here the working version:
At Operation template:
Operation
  $attr=%list="Parameter__Name" @separator="," @indent="  "%
and the Parameter__Name (2 underscore!) template:
%paramName%
Thanks! and best regards,
Guido
