Author Topic: Java debug and sequence diagrams  (Read 4084 times)
soril
« on: January 28, 2007, 10:13:28 pm »
Hello !
There is no way I can get this to work. Is it working better with MDG eclipse plug-in ?
I can build and make the application run but when I click on the "debug" button, it doesn't work. Instead, the following text appears :
"Loading Java Virtual Machine from path ....jre\bin\client\jvm.dll
Obtained Java virtual Machine version 1.4"
And then, nothing ! No error message or anything but no expected behavior neither.
Thank you for your help !
Re: Java debug and sequence diagrams
« Reply #1 on: January 29, 2007, 04:57:27 am »
Check the documentation carefully. I'm not sure (since I don't debug Java sessions) but I think I remember a minimum version of 1.5 someplace.
soril
« Reply #2 on: January 29, 2007, 06:12:53 am »
I tried with JDK 1.6 also without success.
« Reply #3 on: January 29, 2007, 01:04:05 pm »
Is the JVM in your Windows path?
soril
« Reply #4 on: January 29, 2007, 02:42:05 pm »
I can type "java" anywhere and it will run the JVM (the PATH environment variable is already set to include the JDK).
Thank you guys for your help ! I'm trying to make this work, without success so far. If you have any idea, please let me know since I want to try this reverse engineering for the sequence diagrams but I can't make that feature to work.
« Reply #5 on: January 29, 2007, 03:05:43 pm »
That's all I can think of.
However, by no means does that suggest there isn't more you can do. Just that I've little experience in this area.
There have been quite a few postings here about Java configuration, including debug sessions. Try a search of the forum.
Experience - happy or otherwise - has taught me that you should try several search word combinations. Also, remember to go back quite a ways. Try 500 days or so.
soril
« Reply #6 on: January 29, 2007, 03:54:24 pm »
Thank you for your help ! :)
When I search the forum, I cannot find anyone that make it work.
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1168274538;start=0#0
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=Automation;action=display;num=1166040545;start=0#0
So I don't know if that feature is working at all. The EA documentation doesn't seeem clear and I have seen a demo (http://www.sparxsystems.com/resources/demos/index.html)
But the demo doesn't work even if I follow these steps !
I must be doing something wrong... but the feature surely is not easy to use.
Thank you again for your time
soril
« Reply #7 on: January 31, 2007, 12:23:05 pm »
I tried MDG Eclipse and it seems that I cannot generate sequence diagrams using the EA interface anymore. Is that correct ?
My hope was to be able to integrate eclipse with EA so that I could debug in eclipse and be able to generate the corresponding sequence diagram, the same way it happens if I could make the java debugger work in EA (without the MDG plug-in) but that doesn't seem to be true. Documentation does not mention this.
Thank you for assistance.
