Author Topic: About the deploy command...  (Read 2864 times)
incanus
« on: January 31, 2007, 11:26:33 am »
How is that the deploy command works, i mean that how i should use it, i looked in the EA user guide, but it didnt work for me...
Any explanation would be welcome.
Best regards.
incanus
Re: About the deploy command...
« Reply #1 on: February 01, 2007, 06:55:28 am »
i really need help on this subject, not only for the deploy command of EA but for the deploy of java aplications (not web).
i will appreciate any information you could supplie.
Best regards.
« Reply #2 on: February 01, 2007, 01:00:57 pm »
The deploy command is just a command that you could use on the command line to deploy (in whatever way necessary) your application.  Its meaning and use is completely up to you.
If you get stuck with how to use it, start by working out what you need to do on the command line.  Put the sequence of commands into a batch file and tell EA to call that file.
