Author Topic: Version 5.0 - Build 769 Released  (Read 19489 times)
sparks
« on: August 21, 2005, 09:02:06 pm »
Fixed issues regarding exporting of tagged-values of type <memo> in XMI 1.2
Modified the (CVS) version control File History dialog, making it resizable.
Made Delphi parser delete property tags not found in code.
Added support for array types in Delphi.
Fixed conditional lists of parameters in code template framework.
Fixed the classComplexity code template macro.
Added support for Nested annotations to Java parser.
Generate DDL - add option to place terminator on same line as statement or on new line following statement.
Fixed type field in Auto Counters dialog for Windows 95/98/NT/2000 platforms
Fixed opening properties for stereotyped attributes from Project Browser
Fixed calculation of Use Case Metrics report "Total Use Cases" field
Fixed retrieval of float values from repository (fixed incorrect decimal values in Use Case Metrics report)
Added automation property: Connector.StateFlags
Copying of table 'column' attributes no longer copies PK/FK flag
Tab characters in Notes elements now get expanded when rendering
Fixed bug when Deleting items from Database Datatypes dialog when multiple items have same name
Removed Duplicate Att.Notes field in "(basic template)" RTF Document Template
Corrected issue whereby profile tags would not save when invoking "Save Package as Profile" from the project View.
Corrected issue where Diagram content would incorrectly render using the RTF Document Generator.
Fixed issue whereby Sequence lifeline occurences would incorrectly draw when "Assume Return" was enabled.
Added support to persist the View->Field Names option in the RTF template editor.
Corrected issue where element substates would incorrectly render to the RTF Document Generator
Added Element.Abstract, Element.GUID, Diagram.GUID, Package.Abstract, Package.GUID, Attribute.GUID, Method.GUID, Connector.GUID, Element.FullName Fields to the RTF Document Generator
Corrected various rendering issues with the Child Package RTF Document Section
Fixed issues with Element, Package and diagram ordering when Generating RTF Documents.
Fixed "Write Always" checkbox option to not generate intermediary file on Transformations after file name has been set.
Added support for custom Codepage and Languages with the revised RTF Generator.
Fixed inserting object scenarios greater than 4000 chars on Oracle repository.
Fixed Generation of Single DDL file from multi-select when including elements not of "table" stereotype.
Fixed sorting on Date column in System window, Model Issues tab.
Allow multiple users may to use shared keys on one machine (including Terminal Server users).
Allow shared keys to be used on installations where user install directory is locked down.
Corrected issue with default Document Section ordering in the RTF Template editor.
