Author Topic: Newbie question - How to get rid of red triangles?  (Read 4872 times)
dampbarn
« on: February 04, 2007, 06:00:31 am »
Hi, I actually have two questions.
When I make requirement diagrams, I sometimes see a red triangle appearing on top of a requirement. I have not found out how this appears. Does anyone know the meaning? And most important: How to remove it?
When I use default diagrams - when starting a new project - the creation date is very old. Is there a way to modify the default diagram dates? How?
dampbarn
« Last Edit: February 05, 2007, 02:05:05 pm by dampbarn »
Re: Newbie question
« Reply #1 on: February 04, 2007, 06:39:20 am »
Search the help for Bookmark
Re: Newbie question
« Reply #2 on: February 04, 2007, 01:51:19 pm »
And for the second part of your question, Tools -> Options -> Diagram and check the "Allow change of Created Date" option.
dampbarn
Re: Newbie question
« Reply #3 on: February 04, 2007, 04:09:30 pm »
Thanks a lot.
For the change date option. If a creation date is already in the diagram (using select models to add to your project), how do I change that so that the diagram header shows the creation date, I want. If I check the allow change of creation date, I can change the creation date in properties, but the header still shows the old creation date - I guess it is the date of the sample creation. Can I change this default date?
Thanks again.
dampbarn
mikewhit
  • Accessing ....
Re: Newbie question
« Reply #4 on: February 05, 2007, 06:03:41 am »
Your Subject says "newbie question" but fails to mention the question - please include some mention of the question in your subject line.
Also, searching the forum with text "red triangle" would have solved your question, so that's usually the best approach initially.
dampbarn
Re: Newbie question - How to get rid of red triang
« Reply #5 on: February 05, 2007, 02:05:41 pm »
Thanks! I hear you :)
dampbarn
