Author Topic: New categories in Model Wizard  (Read 3887 times)
fballem
« on: March 01, 2008, 11:09:07 pm »
Currently, there are two groups of models that are used when starting a new project in EA - <default> and Iconix. Depending on the option selected, there are then additional profiles available from which the user may select one or more.
Is there any documentation on how to add a customised option to the Model Wizard?
Re: New categories in Model Wizard
« Reply #1 on: March 02, 2008, 12:30:08 am »
Yes,
You'll find the necessary pointer in the EA Help file. As of build 826 - I think it has been the same for a few builds - the relevant page is in the SDK section. The final section is titled MDG Technologies in SDK. The last page in the index will give you an overview. You'll have to work through the rest of the section to use it.
Sadly, the documentation has not quite caught up to the product. Sparx is actively working on improving this, so make sure you refresh your help file and user guide with each build.
HTH, David
fballem
« Reply #2 on: March 02, 2008, 02:08:28 am »
Thanks, I'll check it out.
