Author Topic: MagicDraw Import Problem  (Read 3466 times)
bscott
« on: February 11, 2007, 12:19:34 am »
I have a trial version of EA 6.5 and am trying to import class diagrams from MagicDraw 9.5 Community Edition. The classes get imported but the association don't.
I have created a simple class diagram in MagicDraw with just two classes and an assocation to try this out.
I downloaded a trial of the Visual Paradigm UML tool and imported from MagicDraw into that Ok. If I then export from VP and import into EA I get the associations.
Is this a bug in EA?
Re: MagicDraw Import Problem
« Reply #1 on: February 11, 2007, 03:45:00 am »
Don't know. Search this forum for MagicDraw, since there has been discussion about this in the past.
If you don't find anything useful consider reporting this to Sparx as a bug. Use the Support link above the forum page, then click Bug Report on the left-side menu.
You should attach the XMI output from both MagicDraw and VP so Sparx has something to work with.
bscott
« Reply #2 on: February 11, 2007, 08:10:29 am »
I couldn't find anything in the forum realting to this.
I have emailed support with the xml files as I couldn't see how to attach them to a post.
jeshaw2
« Reply #3 on: February 11, 2007, 04:10:45 pm »
You might also consider reporting it as a bug to Magic Draw.  8)
