Author Topic: Problems with FK in Data model using MySQL as repo  (Read 9068 times)
mogarick
« on: February 09, 2007, 11:05:08 am »
I'm having trouble when trying to edit or create a new FK association for my Data Model when using MySQL for storing the model repository. I'm getting the next error message:
Microsoft OLE DB Provider for ODBC Drivers [-2147217900]
[MySQL][ODBC 3.51 Driver][mysql-5.0.27-community-max]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ON t_object.GenType=t_datatypes.ProductName AND t_object.Object_ID=t_attribu' at line 1
After 2 identycal messages it opens the FK dialog but the involved tables attributes neither appear in the source and target area.
I hope you can help me to find a solution.
The version is 6.5.801
Greetings.
Ricardo Montoya
« Last Edit: February 09, 2007, 11:09:39 am by mogarick »
peter.zrnko
Re: Problems with FK in Data model using MySQL as
« Reply #1 on: February 10, 2007, 09:29:09 pm »
Have you seen "Create and Open Model Files Discussion"
"MySQL Limitations" in the help file?
(Justfor a case. I'm not using MySQL.)
Peter
mogarick
« Reply #2 on: February 12, 2007, 08:48:11 am »
I have read it.
I have MySQL version 5 installed and my ODBC driver is 3.51 so I can't understand why it's not working.
I created the repo schema with the Innodb EA script.
When I use the EA file I don't have this problem.
Can anyone help me with these please? ???
I've already checked the 2 special options for the MySQL ODBC connection. (Don't optimize column width and Return matching rows)
Greetings
hd
« Reply #3 on: February 12, 2007, 01:09:52 pm »
This issue has been resolved for the next release.
