Author Topic: Version 5.0 - Build 770 Released  (Read 19307 times)
sparks
« on: September 07, 2005, 09:24:48 pm »
Fixed Automation Interface issue (introduced in 769), that caused EA.Connector interface to be incompatible with previous builds.
Note : Automation clients compiled against build 769 need to be recompiled against build 770.
Fixed error that occured when reverse synchronising a class with an existing association.
Fixed RTF Report Bookmarks to cover the selection range for the section bookmarked.
Added Field Attribute.Length to the RTF Generator.
Added support for Model Document and Single-element document generation using the revised RTF Generator.
Corrected issue with invalid compare status for Test Acceptance Criteria field in Acceptance Test.
Minor corrections to floating-point results compared by the compare Utility
Fix to prevent EA Crashing when cancelling Code Package Imports
Fix to correct item ordering in the Element.TaggedValeuesEx Interface method
