Author Topic: Move External and Auto Name Counters  (Read 2245 times)
PM
« on: February 27, 2007, 07:43:07 am »
Hi all,
 I have found that when I have an auto name counter set for requirements; and I create an internal requirement (on a use case) then move external the requirement doesnt get auto named. Explicitly created external requirements get auto names OK.
 My question(s) :
 Is this expected or broken behaviour?
 Is my use of move external unexpected when I have existing external requirements.
Thanks in advance.
 EA version 6.5.803 Pro edition.
PM
Re: Move External and Auto Name Counters
« Reply #1 on: February 27, 2007, 12:34:14 pm »
Hard to tell. There has been quite some discussion around internal (responsibilities) and external requirements (try a search). The auto-counters itself do not work very consistent. Sometimes they are auto-generated, sometimes you need to press a button. Most times the generated counter is selected so you need to right-move to add the real name. I guess you are out of luck when asking for improvements here (there have been some requests, still on our wishlist).
PM
« Reply #2 on: February 28, 2007, 03:18:32 am »
 Thanks for the info.  Ill work around this by only using the external requirements.
Regards
PM
