Author Topic: MySQL and Comments for Columns - ddl-generation  (Read 2700 times)
AxelM
« on: February 07, 2007, 01:20:48 pm »
i want set comments for each column in a table. Ok, if i have default values than i can add the comment like this "comment 'x'" for the column in the initial field after the default value.
but i have not everytime a default value.
For example, i want this from the generator:
CREATE TABLE foo
   X int COMMENT 'description',
and not this one:
CREATE TABLE foo
   X int DEFAULT COMMENT 'description'  //
i try to set the comment with a tagged value for a column, but this will not working.
what can i do?
Thanks Axel ???
AxelM
Re: MySQL and Comments for Columns - ddl-generatio
« Reply #1 on: February 28, 2007, 05:01:32 am »
this problem is solved.
In the Dialog "Genereate DDL" ComboBox "Comment Level" the defaultvalue is Table. The choice now is Column an will work now fine without hacks.
Now, i have an other problem with generating FK.
Example:
Table 1: (Stereotype <<Table>>)
idint (Primarykey)
typeidint (Foreignkey)
Table 2: (Stereotype <<Table>>)
idint (Primarykey) is Foreignkey for Table 1
The Output sql for table 1 is wrong for mySql:
DROP TABLE IF EXISTS foo ;
CREATE TABLE foo
id INTEGER NOT NULL AUTO_INCREMENT COMMENT 'ID',
typeid INTEGER NOT NULL COMMENT 'Typeid',
PRIMARY KEY (id),
KEY (typeid) // this one will NOT work
ALTER TABLE foo ADD CONSTRAINT FK_typeid
FOREIGN KEY (typeid) REFERENCES footpye (id) ;
O.k. I thing i must change the Transformationtemplate for DDL. It sems that i work on the false template, because i can change everything, delete for example completly the classtemplate  and  i will get the same output or it has no effect. It's happen also i restart EA.
My Question is now:
Where and what for a template must i change,so it produce this output:
CREATE TABLE foo
PRIMARY KEY (id),
FOREIGN KEY (typeid) REFERENCES footpye (id) ; // so is it ok
Thanks for any idea.
