Author Topic: Placing XMI files from CVS in directory structure  (Read 2510 times)
morsor
  • insert text here
« on: February 28, 2007, 02:40:10 am »
When configuring a package for CVS, EA suggests the location CVS_ROOT/<package-name>.xml
Instead of placing all packages in the root, we created a directory structure mimicking the project structure:
Model
- Requirements Model
-- Use Case Model
--- Use Cases
---- Use Case 1.xml
---- Use Case 2.xml
---- Use Case 3.xml
In the beginning, this went fine - but now all of a sudden EA just hangs after selecting the package XML file location and pressing OK.
It seems to be a CVS problem, as killing cvs.exe in the TaskManager brings up the confirmation window and the process resumes as normal, writing XMI to the file system under CVS control.
A CVS Update was performed before attempting to configure the packages for CVS - but no luck.
Any ideas? Or should the XMI files simply not be put into directories not under EA control?
« Last Edit: February 28, 2007, 02:41:07 am by morsor »
morsor
  • insert text here
Re: Placing XMI files from CVS in directory struct
« Reply #1 on: February 28, 2007, 06:17:02 am »
Problem (apparently) solved.
Installing various CVS clients had added loads of junk to the environment variable PATH.
Editing it manually has solved the problem.
