Author Topic: add link to my own use case scenario template  (Read 3977 times)
cvergara
« on: February 28, 2007, 05:36:45 am »
Guys, i need your help..
i built my own use case scenario template, but i can't add link in the document.
when i create my use case and document it, the template doesn't document this eyelash..
sorry for my english..
i am from chile..
peter.zrnko
Re: add link to my own use case scenario template
« Reply #1 on: February 28, 2007, 06:49:39 am »
What do you mean by "use case scenario template"?
Do you use profiles?
What do you mean by "document"?
Did you generate a document?
Try to discribe what do you want to achieve
and step by step what you have done.
Peter
« Reply #2 on: February 28, 2007, 07:12:18 am »
And please remove the duplicate message in the other forum section.
cvergara
« Reply #3 on: February 28, 2007, 07:34:55 am »
Peter..
thanks for your  help
First step: i create my use case diagram and his documentation
Second step: i create my own use case scenario template
Third Step: i add a "diagram image", constraint, requirement, scenarios and Files relationated in the use case template, but i can't add link
i don't use profiles, i generate a use case scenario template document by EA 6.5..That's all
peter.zrnko
« Reply #4 on: February 28, 2007, 12:23:57 pm »
In elements properties there is a "Link" tab and you're right, it's not possible to add links in this tab.
Read help on "Connecting Elements" or "The Quick Linker" or "The UML Toolbox". There is a lot of ways, how to create a link.
Peter
cvergara
« Reply #5 on: February 28, 2007, 12:57:53 pm »
Peter you are not understand me..
i need to add the item "link" in my own use case scenario template (RTF document), not in my use case....do you understand me?
thanks you...
peter.zrnko
« Reply #6 on: February 28, 2007, 11:09:09 pm »
Check the "Connector" section in the Content panel of rtf templates editor.
Then you can arrange your template like this:
connector >
source >
element >
{Element.Name}< element
< source -> target >
element >
{Element.Name}
< element
< target
< connector
All your links will be in the generated rtf document. Unfortunately there is no way to filter these links e.g. by stereotype.
Peter
