Author Topic: Question: File size when controlling packages  (Read 3647 times)
shaft
  • I love YaBB 1 Gold!
« on: September 14, 2006, 03:30:12 pm »
Question:  Why does my file size EXPLODE when I control packages and save to XML files?
I'm stuck using clearcase so I have to control packages using the saved XML files.  However, in doing so I 've noticed my .eap file size has gone from a couple megs to over 60 megs.
The saved xml packages aren't even close to that big.  The eap file before the saving of packages wasn't close to being that big.  What happend?
Jeff
Re: Question: File size when controlling packages
« Reply #1 on: September 14, 2006, 03:48:21 pm »
Try running Tools | Manage .EAP File | Compact .EAP File from the main menu of EA.
See http://www.sparxsystems.com/EAUserGuide/index.html?o548.htm
It may not help, but then again it may.
« Last Edit: September 14, 2006, 03:48:54 pm by simonm »
shaft
« Reply #2 on: September 14, 2006, 03:52:16 pm »
That did...  I'm back to a reasonable size again.  Thanks.
ligwalker
  • Bluestar
« Reply #3 on: March 06, 2007, 10:00:29 am »
Hi Jeff,
I'm not sure if you are still working at the same place.  If you are I'd like to talk to you about EA and using ClearCase to version control the xml files.
Linda
