Author Topic: Formating the Reengineered Class diagram  (Read 2335 times)
Vista
« on: March 04, 2007, 09:41:19 pm »
I have created ClassDiagram using reverse engineering of my source code, but the diagram is so mixed up . Is there a way to format and align it in a neat fashion. Doing so manually is tedious ..
Any help is appreciated
Re: Formating the Reengineered Class diagram
« Reply #1 on: March 05, 2007, 05:32:05 am »
You can have EA to do this automatically: Tools/Options/Code/Auto layout
Or you open the diagram and press the according layout button.
Vista
« Reply #2 on: March 07, 2007, 12:26:35 am »
Thanks for the reply,
I tried both the ways , seems there is no change .
« Reply #3 on: March 07, 2007, 12:42:10 am »
So your problem is the result of the auto-layout. There are a few layout options you can set in the diagram's properties. Also you can auto-layout just selected elements. Doing it that way in pieces might help. Else you are out of luck and need to re-work manually.
