Author Topic: Generating code with attributed COM  (Read 2460 times)
ronid
« on: March 08, 2007, 04:25:46 am »
I am using attributed COM. This means that before my interfaces and classes I have the following code:
object,
uuid("76713711-15B4-4AA9-AAC5-73431671EBCA"),
helpstring("IFoo Interface"),
pointer_default(unique)
__interface IFoo : IUnknown
or
coclass,
threading("both"),
support_error_info("IFoo"),
event_source("com"),
vi_progid("Foo.CFoo"),
progid("Foo.CFoo.1"),
version(1.0),
uuid("1FC9DD93-B7D4-4B5E-A649-CE6AE15FFC5B"),
helpstring("CFoo Class")
class ATL_NO_VTABLE CFoo:
public IFoo
When converting from code to EA the converstion is OK, but when updating the model and then generate the code the attribute part gets deleted. I can't use the code generation templates since I need to create the code with a special GUID (i.e. a unique key).
Any suggestions?
Roni.
ronid
Re: Generating code with attributed COM
« Reply #1 on: March 08, 2007, 09:42:55 am »
Hi again,
I have managed to progress a little bit. I defined the following in the transformation templates for class declaration:
%elseIf classStereotype=="coclass"%
[\n
coclass, \n
threading("both"),\n
support_error_info("ICimE30"),\n
aggregatable("never"),\n
vi_progid("SECSGemDriver.CimE30"),\n
progid("SECSGemDriver.CimE30.1"),\n
version(1.0),\n
uuid(%classGUID%),\n
helpstring("CimE30 Class")\n
]\n
Now I have 2 problems:
1. The uuid(%classGUID%) gives me the following:
uuid({DBE4CA33-8B67-432a-83D9-DBDF107F4A4B})
but what I need is
uuid("DBE4CA33-8B67-432a-83D9-DBDF107F4A4B").
2. Once problem 1 solved, I am ok with generating new COM objects from the model. But what happen if the class were add to the model from the code, then I modify from the model and I want to stick with the original GUID.
Roni
