Author Topic: Help needed for Building a project  (Read 6904 times)
Vista
« on: March 07, 2007, 08:50:34 pm »
hi,
I am trying to build the project ,but get fatal error CS2008.
This is what i am doing .I have imported my .NET c# classes from the root path.
I am setting the PackageBuild script as follows
Build Path as :C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\csc.exe
Run Path as : C:\INTER\MYTIME\BController\obj\Debug\
Debug  as: Inter.MyTime.BController.dll
Am i doing mistake in my settings?? Please help
Re: Help needed for Building a project
« Reply #1 on: March 07, 2007, 09:01:54 pm »
You need to tell the compiler what to build.  (That error message is no inputs specified)
Have a look at http://msdn2.microsoft.com/en-us/library/78f4aasd(VS.80).aspx for instructions on compiling C# on the command line.
Vista
« Reply #2 on: March 07, 2007, 09:07:12 pm »
Hi simon,
Its not the problem about building , I am able to build it using Visual Studio. But am not able to do it using EA . I need to generate sequential diagram and that is why this excercise..
Regards
« Reply #3 on: March 08, 2007, 01:04:53 pm »
Vista
« Reply #4 on: March 08, 2007, 05:48:12 pm »
ok Simon Thanks,
It says the debugging of assemblies are supported only with .NET version 2 . I am using a lesser version.
That means i wouldnt be able to reengineer Sequence diagram .
Vista
« Reply #5 on: March 12, 2007, 04:51:36 pm »
Hello Simon,
I have .Net version 2 . trying to Build and Debug my project for Reverse Engineering Sequence Diagram. Somehow out of luck .
According to the UserGuide
type_name, method_name, { method_argument_1, method_argument2,....}
I have set the Debug tab as follows:
XXX.YYY.Login.BusinessController.dll
and the variables as
XXX.YYY.Login.BusinessController.LogInInfoController.ExecuteBusinessLogic,ExchangeDataSuper,SessionInformation,config
where ExecuteBusinessLogic is the METHOD , ExchangeDataSuper ,SessionInformation ,Config are all instances of class .
I still get the same error while building the project .
Let me know if i am doing wrong .
Thanks for all your help
« Reply #6 on: March 12, 2007, 05:54:00 pm »
From looking at the help link above it appears that your run time variables are incorrect.  You need to have a comma, not a full stop between your type_name and your method_name.
Vista
« Reply #7 on: March 12, 2007, 05:58:34 pm »
Its the same with coma .
Is it possible to set the Instances as the parameter for the method . I was wondering if that was a problem .
Vista
« Reply #8 on: March 13, 2007, 05:47:49 pm »
Hi ,
What is the Build filename you have to specify while setting.
"C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\IDE\devenv.com" /Build Debug XXX.sln
Is XXX => the Controller dll or the source file???
« Reply #9 on: March 14, 2007, 01:13:00 pm »
You may need to use the relative path to your dll from the base directory of your build script.
By the look of it XXX should be the name of your solution file.
Vista
« Reply #10 on: March 14, 2007, 04:29:05 pm »
Thanks for the reply.
I have used
"C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\IDE\devenv.com" /Build Debug BusinessController.csproj
for build and could successfully build .
Where as i have problem with the debug , can u help me please
classname
obj\Debug\Int.Real.Login.BusinessController.dll
Variables
Int.Real.Login.BusinessController.LogInInfoController.ExecuteBusinessLogic,ExchangeDataSuper,SessionInformation,SystemConfiguration
With this ,
15/03/2007 09::26 Default Directory is C:\Int\Real\BusinessController\
15/03/2007 09::26 Debugger CLR runtime version is v2.0.50727
15/03/2007 09::27 Process created \Device\HarddiskVolume1\Program Files\Sparx Systems\EA Trial\SSInvoke.exe running CLR version v2.0.50727
15/03/2007 09::27 Debug process in domain DefaultDomain
15/03/2007 09::27 Debug process in domain SSInvoke.exe
15/03/2007 09::27 debug ends for SSInvoke.exe
But it doesnt stop at the breakpoint . The Stack Record button and the sequence diagram buttons are disabled .Am not able to test the version for the purpose of Generating sequence diagram .
Kindly help
« Reply #11 on: March 14, 2007, 04:38:25 pm »
Have you reverse engineered the code into EA?
Vista
« Reply #12 on: March 14, 2007, 04:39:22 pm »
Reverse Engineered the code=My class diagram is reverse Engineered .
Vista
« Reply #13 on: March 14, 2007, 05:09:13 pm »
Simon,
I have followed exactly the same procedure as the Demo . Except that i am using the dll , where as in the Demo it is Exe.
NOTE: In the ProjectBuildScript, the Debug is not marked . though i have made the settings .
Vista
« Reply #14 on: March 14, 2007, 10:31:35 pm »
Any Ideas about this error during DEBUG
Suitable method not found!
Here are the reasons:
Int.Real.Chart.BusinessController.QueueTransaction.ExecuteBusinessLogic:Argument Conversion Failed
System.Object.GetType:MethodName Doesn't Match!
System.Object.ToString:Method Name Doesn't Match!
System.Object.Equals:Method Name Doesn't Match!
System.Object.GetHashCode:Method Name Doesn't Match!
Where QueueTransaction is a Controllerclass , ExecuteBusinessLogic is the method in the controller class
