Author Topic: Show Column Note In Table ?  (Read 5266 times)
Maziar
« on: March 20, 2007, 12:54:07 am »
Hi
[(data model)]
i use EA for non English language
then my user must see translate of column name in Table (when print it)
have EA any Feature can show Column Note after column name the same as view of lnitial value in table ?
Re: Show Column Note In Table ?
« Reply #1 on: March 20, 2007, 01:50:07 am »
You're probably out of luck here :-/
peter.zrnko
« Reply #2 on: March 20, 2007, 02:08:18 am »
What about "Alias"?
In exported documnetation you can see both name and alias.
Peter
« Reply #3 on: March 20, 2007, 02:11:10 am »
But not for column names. Only for class/table names...
Nonsense... :-[
« Last Edit: March 20, 2007, 10:17:55 am by thomaskilian »
peter.zrnko
« Reply #4 on: March 20, 2007, 05:55:51 am »
What is the problem with aliases for attributes (column names)?
Every attribute can have an alias.
Peter
Maziar
« Reply #5 on: March 20, 2007, 06:47:53 am »
but also alias dont show in column section !
i use Firebird Database in firebird we use "Description"
for this use .....
« Reply #6 on: March 20, 2007, 10:17:19 am »
Oops. I must be blind. Never noticed the alias property. So forget my entry above.
You have to use "Use alias if available" in the diagram properties.
Maziar
« Reply #7 on: March 20, 2007, 11:12:42 am »
but IF "Use alias if available" then i can not see "Name"
i must see both: description & Name
« Last Edit: March 20, 2007, 11:14:17 am by Maziar »
« Reply #8 on: March 20, 2007, 01:07:00 pm »
Then go to Tools | Options | Diagram | Behavior, and select 'Alias and Name'.
Maziar
« Reply #9 on: March 20, 2007, 08:04:58 pm »
THX
this plain what EA is BEST  ;D
