Author Topic: CodeGen: Prevent Finalizer in C#I  (Read 4599 times)
eAndy
« on: March 24, 2007, 04:20:52 am »
Generating code in C#.
I always get a destructor/finalizer when generating C# code.
Drives me nuts. Has always worked this way.
Typically I have to mod the code template to exclude it.
This time I want an answer if any one has one.
In the code template I see this
%if genOptGenDestructor == "T" and classHasDestructor != "T" and classHasFinalizer != "T"%
I believe the getOptGenDestructor is the setting in the Tools-Options-ObjectLifetime
Where are the classHasDestructor and classHasFinalizer.
I'm guessing they're on the class but I'm certainly missing something.
« Last Edit: March 24, 2007, 05:10:14 am by eAndy »
Re: CodeGen: Prevent Finalizer in C#I
« Reply #1 on: March 25, 2007, 01:13:31 pm »
classHasDestructor and classHasFinalizer return "T" if the current class has a method matching the pattern expected for a destructor or finalizer respectively.  You can't modify their results without adding a destructor or finalizer to your class.
If you've turned off the option to generate a destructor in Tools | Options | Object Lifetime, then a destructor won't be generated.  You'll also want to turn off Tools | Options | C# | Generate Finalizer.  There is also Generate Dispose on the same page.
eAndy
« Reply #2 on: March 27, 2007, 01:26:41 pm »
have you tried this in C#?
I've turned off the option to generate a destructor in Tools | Options | Object Lifetime, and turned off Tools | Options | C# | Generate Finalizer and turned off the Generate Dispose on the same page.
Generate code.... Whoop! there it is! A dirty no good down low nasty old destructor/finalizer.
Any other ideas?
« Reply #3 on: March 27, 2007, 02:37:06 pm »
Not immediately before replying to your question, but I have done it MANY times.
Any other ideas?
I suspect that the option is set on the class itself.  To check what options are set, open the Code Generation dialog (Select single class, press Ctrl+G) and press the advanced button.
To clear the options for all of your classes so that they use the model options have a look at http://www.sparxsystems.com.au/EAUserGuide/index.html?resetoptions.htm.
eAndy
« Reply #4 on: March 27, 2007, 06:16:59 pm »
That was it.
There's an advanced button on the Code Generation window.
If you go into "code lifetimes" its a duplicate of the Tools - Options - code lifetimes but they're disconnected and not saving the data in the same place.
I'd say dumb only b/c I haven't found a good use for it yet and its been very frustrating finding it.
I'm certain there will be a day when I'm singing its praises and calling the designers genius.
sargasso
RESOLVED: CodeGen: Prevent Finalizer in C#I
« Reply #5 on: March 28, 2007, 01:52:09 am »
genius.
???  Eeevil geneii  ???
hth
Lets start using the subject line on posts more constructively.
Andy has done "A good thing" by posting a comment that his issue wa resolved.  I'm just suggesting that it would be nice to see that "outcome" reflected in the subject line.
On the same but a different line.  IF the "discoverer's" of spam could a) add a "SPAM: xxx" to the subject of their spam replies, and b) somehow notify whoever it is at Sparx that is doing the excellent job of de-spamming that "here's another one!", I'm sure we could all get back to whatever normality is in <insert your local galaxy here>.
Coments? Comets? Comments?
bruce
